What Are Some Basic Newtonian Problems?
  • Thread starter Thread starter PhysicsNovice
    Newtonian
The discussion focuses on basic Newtonian physics problems aimed at beginners. Key topics include calculating centripetal acceleration for an object moving in a circle, identifying the necessary centripetal force, and understanding the direction of net force on a car navigating a curve. Additional concepts cover the effects of distance on gravitational force, changes in weight due to alterations in Earth's radius, and gravitational interactions within a hollow planet. The thread encourages feedback on the correctness of these problems to enhance understanding for those new to physics.
PhysicsNovice
Please review the correctness of these basics physics questions. Add any comments or helpful hints to help my rudimentary understanding. I am truly a "physics novice." Thanks.
Physics Problems – Round 2
1. An object moves with a constant speed of 20 meters per second on a circular track of radius 100 m. What is the acceleration of the object?
a. zero
b. 0.4 m/s/s
c. 2 m/s/s
d. 4 m/s/s*
2. What force is needed to make an object move in a circle?
a. kinetic friction
b. static friction
c. centripetal force*
d. weight
3. A car goes around a curve of radius r at a constant speed. What is the direction of the net force on the car?
a. toward the curve's center*
b. away the curve's center
c. toward the front of the car
d. toward the back of the car
4. If a car goes around a curve at half the speed, the centripetal force on the car is:
a. four times as big
b. half as big
c. one-fourth as big*
5. According to Newton, the greater the distance between masses of interacting objects, the:
a. less the gravitational force between them
b. more the gravitational force between them
c. less the force by the square of the separation distance*
d. none of these
6. If the radius of Earth somehow decreased with no change in mass, your weight would:
a. increase*
b. not change
c. decrease
7. The force of gravity acting on you will increase if you:
a. burrow deep inside the planet
b. stand on a planet with a radius that is shrinking
c. both of these*
d. none of these
8. A hollow spherical planet is inhabited by people who live inside it, where the gravitational field is zero. When a very massive ship lands on the planet’s surface, inhabitants find that the gravitational field inside the planet is:
a. still zero
b. non-zero, directed toward the spaceship*
c. non-zero, directed away from the spaceship
9. A very massive object A and a less massive object B move toward each other under the influence of mutual gravitation. Which force, if either, is greater?
a. The force on A
b. The force on B
c. Both forces are the same*
10. A woman who normally weights 400 N stands on top of a very tall ladder so she is one Earth radius above the Earth’s surface. How much does she weigh there?
a. zero
b. 100 N*
c. 200 N
d. 400 N
e. none of these
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
