Origins of Coefficient of Friction and Normal Force
The discussion addresses the origins and meanings of the coefficient of friction and normal force in physics. The coefficient of friction is influenced by various factors, including surface conditions, and can exceed one in certain material combinations. The term "normal" force derives from Latin, where "norma" refers to a right angle, aligning with its definition as a perpendicular force. It is noted that Coulomb's law of friction is a simplified model that works well in basic physics scenarios but does not encompass all real-world applications. Understanding these concepts requires recognizing the limitations of the Coulomb model and the complexities involved in measuring friction in engineering contexts.
jamesnb
This is my first year teaching High School Physics and I'm finding there are a lot of questions I should have asked 25 years ago when I was in college.
1. Does anybody know what the coefficient of friction is based on? Usually these things are based on something like getting units to cancel or amount of something to do something or an absolute. The only thing I've been able to find is mu of rubber on concrete = 1.0
2. Why is it called "normal" Force. Of course I understand what it is and how to calculate it but I'm at a lose to explain how they came up with "normal" as opposed to something more reasonable like perpendicular, complimentary or even opposite.
Any ideas?
welcome to pf!
hi jamesnb! welcome to pf! :smile:
1. From the PF Library on friction …
Tables of coefficients of friction:
Many tables can be found on a http://www.google.com/search?client...ficients+of+friction+table&ie=UTF-8&oe=UTF-8", which begins
"Extreme care is needed in using friction coefficients, and additional independent references should be used. For any specific application the ideal method of determining the coefficient of friction is by trials. A short table is included above the main table to illustrate how the coefficient of friction is affected by surface films. When a metal surface is perfectly clean in a vacuum, the friction is much higher than the normal accepted value and seizure can easily occur."
For some materials, the coefficient can be greater than one, and for solids on rubber it can be as high as four.​
2. From my copy of Smith's Latin-English Dictionary …
norma a square, employed by carpenters and masons for making right angles​
… so the original meaning of a normal line was the line made by a square (a set-square), ie the perpendicular! :biggrin:
2A. Again from Smith's Latin-English Dictionary …
perpendiculum a plummet, plumb-line
from
perpendo, perpendere to weigh carefully or exactly
from
pendo, pendere to make or cause to hang down, especially of scales; hence to weigh, weigh out
from
pendeo, pendere to hang from on or by something to be hung, suspended
(pendo from pendeo is a causative construction, fairly rare in English … examples are rise and raise, fall and fell … but fairly common in Hebrew and Arabic)
So, etymologically, "perpendicular" should only be used to describe a vertical line in a gravitational field, the line that a plumb-line follows! :smile:
It is the same use of "normal" as in the expression "the normal and tangent to a curve" in geometry and calculus. (OK, that doesn't explain WHY it is called "normal", but at least the usage in mechanics is consistent with something else).
Re friction coefficients, you need to understand that Coulomb's "law" of friction is not really a universal law at all (compared with other laws in classical physics like universal gravitaition of the gas laws). It is just a simple MODEL that describes how to calculate friction forces. It works pretty well for hard, fairly smooth surfaces, large displacements, and fairly slow velocities - in other words the sort of thngs that occur in school physics situations, like blocks sliding down inclined planes.
There are plenty of real life engineering situations where the Coulomb friction model based on constant static and dynamic friction coefficients works very badly. However the alternatives models that work better are too complicated to use in hand calculations, and often they need quite sophisticated experiments to measure the model parameters (i.e. the equivalent of "the friction coefficient").
One downside of this is that many people seem to take away from school-level physics the over-simplified idea that Coulombs "law" tells you everyting there is to know about friction. It doesn't!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
