Solving Magnetic Field Force: Observer I vs Observer II
  • Thread starter Thread starter physicsManiac
    Force
In the discussion on magnetic field force observations, two observers are considered: one moving with two identical charges and another stationary at the origin. The moving observer perceives only an electrostatic force along the x-axis, while the stationary observer detects forces along both the x and y axes due to magnetic effects. The conversation highlights that both observations are valid, as they describe the same physical phenomena from different frames of reference. Additionally, the implications of accelerating frames are questioned, suggesting that calculations in such frames can be complex. Ultimately, the discussion emphasizes the relativity of observations in physics, linking back to Einstein's thought experiments on Lorentz transformations.
physicsManiac
i have 2 questions regarding magnetic field...
1)if 2 identical charges move parallel to each other(along y axis) with relative velocity zero the the observer I moving along with the charges will observe force along one direction only(along x-axis electrostatic) whereas an observer II(standing at origin) watching the charges move away will observe a force on charges along both x and y direction(x and y-axis both i.e magnetic and electrostatic).So what is the correct observation?
2)what will happen if one frame is accelerating ie observer II.
welcome to pf!
hi physicsManiac! welcome to pf! :smile:
if the speed is tanhα, then observer II measures the field as Ey = Ecoshα, Bz = Esinhα.
since the x component of velocity is tanhα, the total force (per unit charge) in the y direction is Ecoshα - Esinhαtanhα, = Esechα, which combined with time dilation gives us the same as the original E :smile:
(that still leaves a magnetic force in the x direction, which curves the path away from the "vertical" … but that's ok because for observer II the charges are not moving parallel to the y-axis, and the faster they move, the greater the angle to the y-axis :wink:)
uhh? :redface: why would anyone want to make calculations relative to an accelerating frame? :confused:
I would say that both observations are equally correct. The same physics happens, just described in different ways.
Wasn't this essentially one of the thought experiments Einstein used to find the Lorentz transformation formulas by the way?
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
