How to calculate the damping factor for a vibrating string?
Calculating the damping factor for a vibrating guitar string requires understanding the relationship between the string's physical properties and its oscillation behavior in air. The stiffness of the string can be calculated using the formula k = AE/L, where A is the cross-sectional area, E is Young's modulus, and L is the working length. While critical damping can be determined using Cc = 2(km)^(1/2), the actual damping coefficient c cannot be accurately calculated without additional information, such as the tension in the string and the effects of sound wave emission and friction. The discussion suggests modeling local viscous dissipation and estimating acoustic dissipation to gain insights into the damping behavior. Ultimately, precise calculation of the damping coefficient remains challenging due to the lack of published data.
deadstar33
I'm running a finite element simulation of a vibrating guitar string, but I do not know how to calculate the correct damping factor for the string as it oscillates in air. I don't have information regarding how many times it will oscillate before the oscillation damps out, but I do have all the physical characteristics of the string. It has a young's modulus of 205 GPa, a Poisson's ratio of 0.31, the working length of the string is 0.648m, the mass of the string is 8.445 x 10^-4 kg, the density of the string is 8890kg/m^3, and it has a radius of 0.2159 x 10^-3 m. I converted everything into S.I units for convenience in the calculations.
Using this data, is there any way to calculate the damping coefficient between the string and air? I've done research but all the methods I've seen of calculating this require values that I don't have, such as the damping coefficient, c. Also, it requires the stiffness of the string, k. Are Young's modulus (E) and stiffness (k) the same thing? Am I correct in saying they are the inverse of each other? As in, 1/E = k?
Thanks.
Edit: My mistake, it's k = AE/L. So I have now applied this formula and calculated the stiffness to be 46.3269 x 10^3 N/m. Using this, I have calculated the critical damping coefficient using the formula Cc = 2(km)^1/2, so that Cc = 12.5097. Now I just need to calculate the damping coefficient, c. Am I using the right method?
No, you don't have enough information to calculate the damping coefficient. The natural frequencies of a string depend on the tension and the mass per unit length (ok, in ideal case). The tension is adjustable (that's how you tune the guitar). Damping of string oscillations is the result of two processes: emission of sound waves (that take the energy out of the string) and friction (which converts energy into heat). The friction is just viscosity of the string but presume the viscosity of the guitar body would also play a role. There is no published data that would let you calculate the damping coefficient (at one point I was looking for that, didn't find anything).
Here's my advice:
(i) Model the local viscous dissipation of the string using two-dimensional Stokesian (non-inertial) flow around a disk.
(ii) If you have one, estimate the total acoustic dissipation from a dB-reader placed near the string (where cylindrical symmetry is strongest.)
Compare the two estimates.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
