Maximum value equation: a constant to the power of x
Pyroadept
Hi everyone, this is part of a longer question, but the current part involves me finding the value of c in the following equation:
L = c^3.(0.5)^(c-1).(0.6)^(c-1).(0.8)^(c-1).(1- (0.5)^c)^42.(0.5)^(8c)
Here's what I've done so far:
I take the natural log of both sides:
ln L = 3.ln(c) + (c-1)ln(0.5) + (c-1)ln(0.6) + (c-1)ln(0.8) + 42ln(0.5^c - 1) + 8c.ln(0.5)
Then differentiate to find the max:
∂(lnL)/∂c = 3/c + ln(0.5) + ln(0.6) + ln(0.8) + [42[ln(0.5)](0.5)^c]/(0.5^c - 1) + 8ln(0.5)
At max, ∂(lnL)/∂c = 0
Relabel [ln(0.5) + ln(0.6) + ln(0.8) + 8ln(0.5)] as (-A) for convenience
Therefore,
3/c + [42[ln(0.5)](0.5)^c]/(0.5^c - 1) = A
Multiplying across by c(0.5^c - 1) gives:
3(0.5^c) - 3 + 42.ln(0.5)c(0.5)^c = Ac(0.5)^c - Ac
Relabel 42.ln(0.5) as B for convenience
Rearranging, we get:
(3 + Bc - Ac)(0.5)^c = 3 - Ac
c.ln(0.5) = ln ((3-Ac)/(3 + Bc + Ac))
And this is where I run into problems, as I can't get rid of the ln on the right side without making an e^c on the left, so I don't know how to isolate the c. I tried differentiating both sides, but I'm pretty sure you can't do that. Is my entire method wrong? The equation at the start is definitely correct though. Please could someone point me in the right direction?
Thanks!
An equation like that, with the unknown value both in, and outside of, a transcendental function, here the exponential, is not going to have a solution in terms of an elementary function. You might be able to change it so that you can use "Lambert's W function", which is defined as the inverse function to f(x)= xe^x
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
