Simple Algebraic Problem (yet confusing 0_o)
  • Thread starter Thread starter Nano-Passion
    Confusing
To solve the equation x = (17/y) - 1 for y, first rearrange it to yx + y = 17. Factoring out y gives y(x + 1) = 17. Dividing both sides by (x + 1) results in y = 17 / (x + 1). This method clarifies the solution process for the algebraic problem. The discussion highlights the importance of rearranging and factoring in solving equations.
Nano-Passion
x= (17/y) - 1
Solve for y.
This is part of a introductory calculus problem.
I've tried everything, I'm not sure what I am doing wrong.
x = (17/y ) - 1
y/1 (x) = ( (17/y) - 1 ) y/1
yx = 17 - y
-y ... -y
yx - y = 17
When you tried this:
yx = 17 - y
You almost had it. Now move y to the other side so yx+y=17. Use what you know about factoring out common terms to solve that problem.
yx = 17 - y
yx + y = 17
y (x + 1 ) = 17 ---- divide by (x + 1 ) on both sides
y = 17 / (x+1)
... Thank you ! =D I've been trying to solve this very simple problem in an excess of at least 10 minutes. =/
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
