Better Model for Radioactive Decay
The discussion focuses on developing a model for radioactive decay that accounts for small time intervals, where the decay constant relates to the half-life and decay rate. The aim is to create a model that allows for multiple decay events within a short period, suggesting a random nonnegative integer with a mean of 1/3. It is noted that the distribution should be asymmetric, with zero probability for negative events and nonzero for positive ones. Poisson statistics are highlighted as a suitable framework for modeling these decay events, as they effectively describe the radioactive decay process. The exponential distribution is presented as the mean of the Poisson distribution in the context of large particle numbers.
MisterX
For the basic model for exponential decay, there is a decay constant, which is related to the half-life. The decay constant multiplied by the number of particles should give the decay rate per second (activity). However, the model I want is for small periods of time. For a small enough period of time, I can come to some conclusion like on average, there is 1/3 radiation event per period. The desired model will have the possibility for more than one event per period, even in this situation. So I could take a random nonnegative integer with probability distribution having 1/3 mean. But how do I find out what the distribution is? One thing that is apparent is there should be zero* probabilty of negative events. However the probabilty of any postitive number events it seems, would be nonzero. Thus, distribution would be asymmetric. Would you be able to point me to a model or a way to look up the distribution for a given isotope and mode of decay?*assuming the reverse reaction is treated seperately
I think that Poisson statistics describe these sort of problems quite well. I know that a lot of processes are well described using Poisson.
Indeed, Poisson statistics fits radioactive decay to a "T". You can think of the usual exponential distribution as the large-N limit of the Poisson distribution.
http://en.wikipedia.org/wiki/Poisson_process
The decay process has a Poisson distribution. The exponential that is used is the mean of the ratio of the current number of radioactive atoms to the original number.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
