Solving for X inside of a 3X3Matrix
  • Thread starter Thread starter smashbrohamme
The discussion focuses on solving a system of equations using Cramer's rule within a 3x3 matrix framework. The initial setup leads to the equation x(2x-3)-1(2)+2(1)=-4x, which simplifies to 2x^2+x=0. A mistake is identified in the division step, where the incorrect result of 2x^2+1x=0 is derived. The correct solutions found are x=0 and x=-1, but the user expresses frustration over the error in their calculations. Ultimately, the thread highlights the importance of careful manipulation of equations in matrix algebra.
smashbrohamme
Using cramers rule.
the equation is.
x,1,2
1,x,3 all set to equal -4x
0,1,2
I made my 2x2 matrix like this
x|x,3| -1|1,3| +2|1,x|
|1,2| |0,2| |0,1|
eventually I ended up with x(2x-3)-1(2)+2(1)=-4x
condensed it down to 2x^2-3x=-4x
2x^2+1x=0
x(x+1)=0
x=0, or x=-1.
I go back to plug it in...and its wrong! :(
When you had your initial equation, 2x^2+x=0 and you divided by 2, you got an incorrect result.
smashbrohamme said:
2x^2+1x=0
x(x+1)=0
Little mistake in this step...
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
