Should metal chimney liners be grounded against lightning strikes?
  • Thread starter Thread starter Spinnor
    Lightning Metal
Metal chimney liners may benefit from grounding against lightning strikes, similar to external TV antennas, especially considering their potential vulnerability. A recent incident highlighted the risks when a lightning bolt struck a chimney, causing significant damage. While some believe grounding could help, others argue that metal chimneys may not reach sufficient height to effectively dissipate static charge. Consulting local building codes or a city Building Inspector is recommended for specific grounding requirements. Ultimately, the effectiveness of grounding metal chimney liners remains uncertain, warranting further investigation.
Spinnor
I was at a home today which a while back had a lightning bolt strike the chimney and explode the top of the chimney off. On the drive home I got to thinking, I have two metal chimney liners, one for a first floor wood-stove and another for the furnace and only the furnace liner is indirectly grounded, I guess, via the furnace ground. If TV antennas need to be grounded should chimney liners be grounded in a manner similar to external TV antennas?
Thank you for your thoughts!
It seems like they should, but I don't know for sure. I'd suggest calling your city's Building Inspector's office to ask. There may be a building code that covers how it should be grounded.
I don't think a metal chimney gets high enough into the air as to drain the static charge off. So I don't think it would make a difference. Look how many times a year lightning strikes communication towers and they generally have a pretty low impedance to ground; certainly low enough to drain charge out of the atmosphere, but they still get plenty of direct strikes.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
