Calculating Relative Phase of Reflected Plane Waves in Lossless Materials
To calculate the relative phase of reflected and transmitted fields for normally incident plane waves, the reflection coefficient is key, defined as Γ = Er/Ei = (η2-η1)/(η2+η1). In lossless materials, the primary phase shift observed is a 180-degree shift when reflecting off a perfect electric conductor (PEC) under specific conditions. For low-conductivity materials, they can often be treated as lossless, simplifying calculations. Understanding these principles is crucial for accurately determining the phase shifts in electromagnetic wave interactions. The discussion emphasizes the importance of distinguishing between lossless and lossy materials in these calculations.
mathplease
not relating to any specific homework question:
how can i go about calculating the relative phase of reflected / transmitted fields for normally incident plane waves?
for example, i know how to calculate the relative amplitude of the reflected field from the reflection coefficient:
\Gamma = Er/Ei = (\eta2-\eta1)/(\eta2+\eta1)
however, what if i want to calculate the relative phase?
Science news on Phys.org
The reflection coefficient should include the change in amplitude and phase. You can get phase shifts if you are talking about lossy materials but given your expression for the reflection coefficient I think you are probably only dealing with lossless materials at the moment. If you are only talking about lossless dielectrics and PEC, then the only phase shift you will get is a 180 degree phase shift with PEC under the appropriate conditions to cancel out the field on the surface.
ah i see. if the conductivity of the material is low can i assume it to be lossless material?
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
