Proving Continuity of Absolute Value Functions | Adv. Calc 1 Homework
  • Thread starter Thread starter chief12
    Calc 1 Continuity
chief12
part 1)Show the function a(x)=|x| is a continuous function from R to R;
part 2)
Prove that if the functions f: D--> R is continuous at x=a, then l f l (absolute value of f) is also continuous at x=a.
part 1) since a(x) = |x|, then given any \epsilon > 0, then for all l f(x) - f(a) l < \epsilon, since l x - a l < \delta when delta = epsilon, since f(x) = l x l
part 2) since f is continuous, then the absolute value of f is also continuous since it doesn't change any of the relationships
part 2)
Not quite. Both the argument and the writeup need improvement.
Your final proof for part 1 should look something like this:
Suppose ε > 0. Pick δ = ε (if that is what works). Then if |x-a| < δ you have... At this point you need to give an argument to show that
|f(x) - f(a)| = | |x| - |a| |< ε
I used f(x) instead of a(x) for your function so it doesn't use "a" twice.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
