Anyone familiar with MIPS floating point instructions?
The discussion revolves around the challenge of modifying a working integer array code to handle floating point numbers in the SPIM simulator. The user initially presents a functioning integer program that finds the largest number in an array and attempts to adapt it for floating point numbers by replacing integer instructions with floating point equivalents. However, they encounter multiple errors in the process. Key points include the need to use even-numbered registers for floating point operations and the realization that the SPIM simulator does support these operations, which was previously unknown to the user. They express gratitude for the information and plan to further investigate the floating point implementation.
trouty323
Hello all. My task here was to have an array of floating point numbers, find the largest in the array, and store it back into the array. The first code shows a properly working integer interpretation of the task, and the second shows my interpretation of the floating point. I simply tried to swap out any instruction for integers to make it floating point, but I'm getting several errors. I didn't think it would be this complicated.
Code:
	.data
.word 7, 39, 42, 16, 15, 21, 3, 2, 37, 11, 32, 28, 40, 27, 20
	.text
	.globl main
main:
lui $s0, 0x1001		# base address
add $t0, $t0, $zero	# index count
add $t1, $t1, $zero	# max element, $t1 = 0
addi $t5, $t5, 15	# number of elements
add $t2, $t2, $s0	# offset plus base
Loop:
beq $t0, $t5, Exit	# branch if counter is equal to number of elements in array
lw $t3, 0($t2)		# reading first element
addi $t0, $t0, 1	# increment counter by 1
addi $t2, $t2, 4	# increment offset by 4
slt $t4, $t1, $t3	# $t4 = 1 if $t1 is less than $t3, otherwise $t4 = 0
beq $t4, $zero, Loop	# branch to loop if value in $t4 is equal to value in $zero
add $t1, $t3, $zero
j Loop
Exit:
sw $t1, 0($t2)		# store highest back into array
li $v0, 10 		# syscall to terminate
syscall
Code:
	.data
.float 7.5, 39.2, 42.4, 16.1, 15.3, 21.6, 3.7, 2.6, 37.7, 11.5, 32.2, 28.3, 40.8, 27.7, 20.3
	.text
	.globl main
main:
	lui $f11, 0x1001	# base address
	add.s $f4, $f4, $zero	# max element, $f4 = 0
	add.s $f5, $f5, $f11	# offset plus base
Loop:
	l.s $f6, ($f5)		# reading first element
	addi.s $f5, $f5, 4	# increment offset by 4
	c.lt.s $t4, $f4, $f6	# $t4 = 1 if $f4 is less than $f6, otherwise $t4 = 0
	add $f4, $f6, $zero
j Loop
Exit:
	sw $f4, 0($f5)		# store highest back into array
	syscall
Technology news on Phys.org
I'm using the SPIM simulator, but wasn't aware that it supported floating point operations. I found this website - http://www.doc.ic.ac.uk/lab/secondyear/spim/node20.html - that seems to be talking about the SPIM simulator. Maybe this will be of use to you.
One thing that was mentioned is that "floating point operations only use even-numbered registers--including instructions that operate on single floats".
Thanks for the information. I'll look over it and see what I can figure out.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
