Proving moment of inertia of hollow sphere with y^2+x^2=R^2 method
The discussion focuses on proving the moment of inertia of a thin-walled hollow sphere using the equation y^2 + x^2 = R^2. The original poster seeks a solution that avoids multivariable integrals and polar coordinates, except for trigonometric substitution. A participant notes the necessity of including the z^2 term to account for the third dimension in the calculation. The moment of inertia is expressed as I = ∫ r^2 dm, suggesting that dm can be defined in terms of the area of a ring and density. The integration should be performed from y = -R to +R to find the moment of inertia.
parsa418
Could anyone prove the moment of inertia of a thin walled hollow sphere using the y^2 + x^2 = r^2. I have only studied up to single variable calculus. I can take regular integrals but not multivariable integrals. I don't want to use the angle method or any polar coordinate systems except in the part where I might use it for trigonometric substitution to evaluate the integral.
Thanks
Thanks
You are missing a z^2 there for the third dimension.
The moment of inertia is simply:
I = \int r^2dm
Let dm be a slice of the sphere of thickness dy. Can you express dm in terms of area of that ring and density? Then integrate from y = -R to +R
AM
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
