Which is Better for Line Tracking: IR Sensors or Phototransistors?
  • Thread starter Thread starter M.Usman
    Ir Sensors
In a robotics contest focused on line tracking using white tape, there is a debate over whether to use IR sensors or phototransistors. While IR sensors have shown fast response times and effectiveness, concerns arise about their sensitivity to ambient light and reflections, which could interfere with performance. Phototransistors are recommended by others in the field, but the argument for their superiority is questioned, especially since IR sensors have been successfully used in similar applications. The choice may depend on grading criteria, including performance and circuit design. Ultimately, the decision should consider both the specific application needs and the potential drawbacks of each sensor type.
M.Usman
Hi
I'm taking part in a robotics contest and that requires my robot to reach the desired destination using line tracking. The line to be tracked is made of white tape.
Now I'm in a sort of dilemma here. I was in favour of using IR sensors to track my line and through experimentation I found their response time to be quite fast and the sensors were also quite effective may I add.
But I have been advised against using them and instead was told to use phototransistors because that's what everyone else is using! Is this argument a good enough excuse? Also, do Phototransistors really have an advantage over IR sensors?
I would appreciate any help :)
What kind of IR sensors? The kind that are used for receiving remote control signals. If that's what you're using they're high gain sensors with gains in the range of 70 - 80 dB. What are you being graded on? If the grade depends only on performance and as long as they can distinguish the tape from ambient noise, I'd say you're better off with the sensors.
However if you're also being graded for designing the circuit to detect the tape, you may be better off doing the sensor amplifier yourself.
Infra red sensors as used on TV sets require the incoming light to be switching on and off at a rate of 38 KHz, too.
So, you would need to arrange that.
They would probably be too sensitive for this application, though. Just the reflection off a shiny floor would be enough to register as a bright object instead of having to find the white tape.
Agreed. I have played around with them. They have automatic noise suppressor, gain adjuster etc etc, so they are only perfect for communication, not for analogue job like this one.
I had experienced that they are so sensitive at (the brightness level of) evening that they detect remote control ('s IR emissions) like wireless (by detecting it even through multiple reflections from walls and objects in the room). Just trying to give you the sense of its sensitivity.
Given that you apparently have used the IR sensors quite successfully, was the ONLY reason you were advised to use phototransistors because that's what everyone else is using?
Those IR sensors were used for many years in Chamberlain's photoeyes for garage door openers and were finally replaced with photodiodes, not because they didn't work well, but for cost reasons. Even at such close range they didn't pick up reflections from the garage floor or door.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
