Wave vector in curved space-time.
MManuel Abad
Hi there, physics lovers!
Sorry I'm bothering you again. The following may sound as stupid questions, but this is a very hard topic for me, so don't judge me that bad! :)
You see, when we're talking about light in curved spacetime, the geodesic equations (or equations of motion) use an affine parameter \lambda to parametrize its world line (actually I know this thanks to this forum).
Indeed, searching in Section 87 "Motion of a particle in a gravitational field" of the 2nd Volume "The Classical Theory of Fields", from the Course of Theoretical Physics by Landau and Lifgarbagez, I find that these geodesic equations (which are for light, and are for null geodesics, defined as those in which ds=0) look like:
\frac{d^{2}x^{\mu}}{d\lambda^{2}}+\Gamma^{\mu}_{\nu\sigma}\frac{dx^{\nu}}{d\lambda}\frac{dx^{\sigma}}{d\lambda}=0
with \Gamma^{\mu}_{\nu\sigma} being the Christoffel symbols. I also saw that, because the wave vector of light is always tangent to its path, we can write:
k^{\mu}=\frac{dx^{\mu}}{d\lambda}
and then, the geodesic equations look like:
\frac{dk^{\mu}}{d\lambda}+\Gamma^{\mu}_{\nu\sigma}k^{\nu}k^{\sigma}=0
In section 48, Landau defines, talking IN MINKOWSKI (FLAT) SPACE-TIME:
k^{\mu}=\left\{\frac{\omega}{c},\frac{\omega}{c}\textbf{n}\right\}
where n is a unit vector along the direction of propagation of the wave. Then it is obvious that:
k^{\mu}k_{\mu}=0
Then, returning to section 87 and the geodesic equations, Landau says that this very same equation holds, even in a gravitational field (CURVED space-time).
QUESTION 1:
Is this 'cuz k^{\mu}k_{\mu} is a four-scalar and then it's invariant in changes of coordinates, even if they're for non-flat space-time? Or why?
QUESTION 2:
k^{\mu}=\left\{\frac{\omega}{c},\frac{\omega}{c}\textbf{n}\right\} is the form of the wave vector ONLY IN FLAT SPACE-TIME, ISN'T IT? I mean, its form changes in curved space time, actually, the wave vector is what we want to find from the equations:
, isn't it?
Well, there it is. I hope you help me. I thank you very much your attention.
Which equation does Landau say holds? The contraction of 2 vectors is a scalar, and is invariant. If it is 0 in some coordinate system, then it's 0 in every other coordinate system.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
