How to find the solution (x,y)
  • Thread starter Thread starter homevolend
To find the solution (x,y) for the equations x - y = 1 and 2x + y = -4, one must identify the values of x and y that satisfy both equations simultaneously. The geometric interpretation involves finding the intersection point of the two lines represented by these equations. A suggested approach is to solve one equation for y in terms of x and substitute it into the other equation. However, there was a mistake in the calculations where the addition of the equations was incorrectly simplified. The correct method involves adding the equations to eliminate y, leading to the correct solution.
homevolend
The solution (x,y) of the system equations define by x-y=1 and 2x+y= -4 is what
I found x and y intercepts of these and plotted it but don't know what it means by finding the solution.
Finding a solution means finding value(s) of x and y that satisfy both equations simultaneously.
Geometrically, it means finding the intersection of the two lines given by the equations you listed.
Why don't you start by choosing one of the equations, and solving for y in terms of x. Then try substituting that into the other equation.
y =
2 [x-y=1]
-1 [2x+y=-4]
2x-2y=2
-2x-y=4
-3y=6
y=-2
1[x-y=1]
1[2x+y=-4]
x-y=1
2x+y=-4
-x=-3
x=3 I think I did x wrong somehow but don't know what, but I think I did y right.
like that??
homevolend said:
y =
2 [x-y=1]
-1 [2x+y=-4]
2x-2y=2
-2x-y=4
-3y=6
y=-2
1[x-y=1]
1[2x+y=-4]
x-y=1
2x+y=-4
-x=-3
like that??
Everything looked OK until this part:
x-y=1
2x+y=-4
-x=-3
This is wrong because x + 2x does not equal -x.
homevolend said:
x-y=1
2x+y= -4
You can add the equations: y will cancel.
ehild
