Barber's pole - appear faster than light?
The discussion explores the theoretical scenario of a massless barber's pole spinning, where the line on the pole could appear to travel faster than light despite no physical part of the pole exceeding the speed of light. Participants note that this phenomenon aligns with the principles of relativity, which state that no information can be transmitted faster than light. The analogy of a searchlight beam sweeping across vast distances is used to illustrate this concept. While the line may seem to move superluminally, it is not a physical entity, similar to the light beam from a flashlight. Ultimately, the discussion emphasizes that such appearances do not violate the laws of physics.
kyle1320
Hi, so imagine this: You have (for this theoretical situation) an entirely massless barber's pole. When it spins, the speed of the of the circumference of the pole is less than the speed the line appears to travel up (or down) the side of the barber's pole. If you were to spin the pole, could the line traveling up the pole appear to go faster than light, even though no physical part of the pole is traveling faster? Disregarding red / blue shift.
Science news on Phys.org
Welcome to PF, Kyle. Nothing physical is moving faster than c. It's the same idea as the spot of a searchlight sweeping at superluminal speed. The law of relativity states that no information can be transmitted at or above c; that is not violated by the circumstance in question.
It could. Just as if I pointed a flashlight at the Moon, then whipped it around to point it at Ceres.
The "beam" gets from Moon to Ceres - a distance of hunderds of millions of miles - in a fraction of a second.
Of course, the beam is no more a real thing than the imaginary line you attribute to points on the barber pole.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
