How Do You Integrate \( C_\ell \) Using Integration by Parts?
  • Thread starter Thread starter bjnartowt
    Integrating
bjnartowt
consider the integral,
{C_\ell } = \frac{{2\ell + 1}}{{2{j_\ell }(kr)}}\frac{1}{{{2^\ell }\ell !}}\int_{ - 1}^{ + 1} {\frac{{{d^\ell }({{({x^2} - 1)}^\ell })}}{{d{x^\ell }}}{e^{{\bf{i}}krx}}dx}
how do you do it?
l = integer, as in the oft-occurring l*(l+1)*hbar
j sub l = the l-th bessel function
x = cos(theta)
this is related to Shankar 12.6.10
Hi Vela, thanks for your post. I looked up the addition theorem for spherical harmonics as it appeared in Jackson's electrodynamics text (rather than Wikipedia), and tried to use that to represent the Legendre polynomial I have to integrate. I wound up just writing a tautology (e.g., x = x; true, and totally useless). Based on what the attached .pdf says, could you elaborate on what it means to use the addition theorem? Is there some standard trick I should be doing that's written in a math-methods text (e.g., Boas or Arfken/Weber) that I should know of or could read up on?
Sorry, I was thinking of a completely different problem. Just ignore what I said earlier.
I found the problem in Arfken on page 665, problem 12.4.7. You got to:
C_lj_l(kr) = \frac{2l+1}{2}\int_{-1}^1 P_l(x)e^{ikrx}\,dx
The hint for the problem says to then differentiate this l times with respect to kr, then set r=0, and, finally, evaluate the remaining integral.
Ah, brilliant! Something new to try--I found the relation you're talking about, and Arfken/Weber provides enough instruction to get me started and keep me busy for awhile... Be back in a bit, maybe...
it is early so this may be unfounded but could you not use integration by parts
to have a series of expressions like
\Sigma_{j=0}^{l-1} [ \frac{d^j (x^2 -1)^l}{dx^j} e^{ikrx}]_{-1}^{1} + (-1)^l i^l (kr)^l \int_{-1}^{+1} (x^2 - 1 )^l e^{ikrx}
since the series ends at l-1 the terms in the series will all have a factor of (x^2 -1) which is 0 at both +1 and -1 so you are left with the final integral does that help at all
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
