Calculating Force from Pressure in Water Rocket Building
  • Thread starter Thread starter DruJohnson
    Force Pressure
To calculate the force exerted by air pressure in a water rocket, the thrust can be determined using the equation Thrust = mdot * v_exit, where mdot is the mass flow rate and v_exit is the fluid velocity at the nozzle exit. As water is expelled, the gas expands, leading to a decrease in pressure and flow rate, which results in diminishing thrust over time. The weight of the rocket also decreases as water is expelled, affecting acceleration. Unlike gases, liquids like water are generally considered incompressible, meaning temperature remains stable while pressure drops and velocity increases through the nozzle. Understanding these dynamics is crucial for effective water rocket design and performance.
DruJohnson
Hello I am currently building a water rocket. I would like some help on finding the equation for the force that is exerted when I add air pressure to an cylindrical tube filled with water. How can I figure out the force that the water would create when I release it. I hope that someone can help with this problem of mine. I appreciate the help that anyone can offer me.
Thank you,
Dru Jouhnson
For a rocket, the force (thrust) generated is given by:
where,
mdot = mass flow rate
v_exit = velocity of fluid at exit of nozzle
For a water rocket pressurized with air, you could figure out the mass flow and velocity from fluid mechanics. As the water is expelled, the gas expands, pressure drops, flow rate drops, and the thrust drops. Thus, the thrust decreases with time. But the weight of the rocket decreases too, so the acceleration may increase or decrease depending on the variables.
Does the nozzle of the rocket act like the throttle valve in a refrigerator? The pressure of the refrigerant is sharply reduced by the throttle valve which also reduces the temperature of the refrigerant.
Jagella
Not exactly. Since the water is basically incompressible, the temperature will largely be unaffected by the water's travel through the nozzle. The pressure will drop dramatically with a corresponding increase in velocity though (as a rough estimate, you could assume that it is an ideal nozzle, and thus the water's exit velocity is equal to sqrt(2P/rho)).
Are liquids typically incompressible and gases typically compressible?
Jagella
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
