Relationship between C.O.P. and outside air temperature
The efficiency of an air conditioner, indicated by its Coefficient of Performance (C.O.P.), is influenced by outside air temperature, particularly the condenser's location. Placing the condenser in shaded areas can enhance efficiency by lowering its temperature, which in turn improves the C.O.P. The formula COPmax = Te/(Tc-Te) illustrates that maximum efficiency is achieved when the evaporator temperature is significantly lower than the condenser temperature. While the unit's casing may provide some shading, it is generally not sufficient to negate the benefits of additional shading. Therefore, positioning the condenser in a cooler, shaded environment can lead to greater overall efficiency.
timsea81
Since the capacity of an air conditioner is a function of outside air temperature, does it follow that greater efficiency will be achieved by putting the condenser under shade rather than out in the open or on a hot roof? Or does the casing of the unit provide adequate shading to make this difference negligible?
COPmax = Te/(Tc-Te)
This is the maximum achievable COP.
Te is evaporator temperature
Tc is condenser temperature
Generally, Te = Trequired - 10
Tc = Tambient + 10
Yes ! it will
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
