Graphing Quadratic Functions: Domain, Range, and Factoring Help
The discussion focuses on the transformation of the quadratic function f(x) = x^2, specifically analyzing the expression 1/2f(2x+6) - 2. Participants clarify that while the term 2x + 6 can be factored as 2(x + 3), it cannot be factored out of the function f itself. The vertical stretch factor of 1/2 is confirmed, but it does not reduce to zero. Additionally, there are suggestions for clearer notation, including the use of LaTeX for better understanding. Overall, the conversation emphasizes the importance of proper mathematical notation and understanding function transformations.
Nelo
Given f(x) = x^2 Sketch the graph of each of the following, state the domain and range.
- 1/2f(2x+6) -2
y=x^2
I Simply have a question. The question is, that this 2x can be factored out from the brackets correct?
Factoring that 2 will multiply it with the 1/2 and make the vertical stretch a factor of 1 , esentially, a factor of 0. No?
Or , would it create -1/2f(2(x+3) -2 , where the horizontal still exists as 2 (1/2) and the vertical still exists as 1/2 ?
Which one is it?
- 1/2f(2x+6) -2
y=x^2
Which one is it?
You need to use parentheses when writing your formulas so we can understand what your formula is. What all is in the denominator? And after the / your parentheses are unbalanced. Anyway, whatever you actually meant, no, you can not factor the two across the f, if that is what you are asking.
I think he/she's asking if you can factor out the 2 in 2x + 6, and the answer is yes, you can, as long as you don't bring it outside the f.
I'm guessing that he/she meant to write this:
f(x) = -(1/2)f(2x+6) - 2 = -(1/2)f(2(x+3)) - 2
or this:
f(x) = -\frac{1}{2}f(2x +6) - 2 = -\frac{1}{2}f(2(x +3)) - 2
OP: Maybe you should learn LaTeX.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
