Is the term factorable in this Algebra problem?
  • Thread starter Thread starter Miike012
    Algebra
The term 9a^2 - 6a + 1 - x^2 - 8dx - 16d^2 is factorable. By grouping the first three and the last three terms, it can be expressed as (3a - 1)^2 - (x + 4d)^2. This leads to the factored form (3a - 1 + x + 4d)(3a - 1 - x - 4d). The discussion clarifies that while the expression has factors, it does not represent an equation with roots unless set equal to zero. The final insight emphasizes that if treated as a function in x, roots can be expressed in terms of the constants a and d.
Miike012
Is this term factorable?
9a^2 - 6a + 1 -x^2 - 8dx - 16d^2
I don't see anything that I can group or any simple factors to factor out...
Group the first 3 and the second 3 with careful management of - signs
9a^2 - 6a + 1 - (x^2 + 8dx + 16d^2)
= (3a - 1)^2 - (x + 4d)^2
= (3a - 1 + x + 4d)(3a - 1 - x - 4d)
How do you know what the roots are?
Not exactly sure what roots you are after? Expressions have factors - you have done that. Equations have roots - you don't have an equation?
EDIT: The following post spilled the beans about what I was trying to get you to think about.
If it were a function in x where a and d are unknown constants, you could set the factored expression equal to 0, solve for x, and express the roots in terms of a and d.
thank you for your guys help.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
