Why is directional noise correlated noise?
  • Thread starter Thread starter CantorSet
    Noise
Directional noise in acoustics, such as from a ceiling fan, can cause correlated noise at multiple microphones due to the proximity of the noise source, not necessarily its directionality. The correlation between the noise signals at the microphones is influenced by the fact that both capture sound from the same point source, regardless of whether the noise is considered directional or omnidirectional. Mathematically, this noise can be treated as an additional signal source, complicating the analysis due to factors like multipath effects. It is also noted that the time delay variable in the equations should reflect the correct distances from the sound source to each microphone. Understanding these dynamics is crucial for accurate signal processing in acoustics.
CantorSet
Hi everyone,
This is not a homework question but I question I have from reading a signals processing paper on acoustics.
Suppose there is a sound source in a room S(t) and two microphones X_1(t) and X_2(t). Then the standard acoustic propagation model has that
X_1(t) = a_1S(t-\tau_1)+n_1(t)
and
X_2(t) = a_2S(t-\tau_1)+n_2(t)
where a_i, \tau_i, n_i account for signal attenuation due to distance, time delay due to distance and noise, respectively.
But the paper says that if we have directional noise in the room (like a ceiling fan), then the noise at the two microphones is correlated, that is Corr(n_1(t),n_2(t)) \neq 0 [/itex]. <br /> <br /> But it seems to me the directionality isn&#039;t what&#039;s causing the correlation, but more the fact that the noise comes from a fan. That is, if we had an &quot;omnidirectional&quot; fan in the center of the room, the noise between the two microphones would still be correlated.<br /> <br /> Also, how does one mathematically represent noise that is directional?
In this context, I'd have to assume that by "directional", they simply mean the sound has one point source, as you say (and not that it is anisotropic!). On a side note, practically speaking there will be notable multipath, making things more difficult.
By the way, that Tau in the second equation should be tau sub 2, not Tau sub 1 (unless the microphones are the same distance from the sound source)
To mathematically describe noise that comes from a point source (described here as "directional"), treat it as if it were just another signal source term, albeit an undesirable one.
Thanks for your help, Fleem.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
