How to Multiply Matrices I and Calculate the Inverse of Matrix B?
  • Thread starter Thread starter Peter G.
    Matrices
The discussion focuses on the steps to demonstrate that a matrix B satisfies the equation (B-pI)(B-qI) = 0 and to calculate its inverse as B-1 = 0.5(3I - B). Participants clarify that the task involves multiplying matrices and showing that the result equals zero. They emphasize the importance of expanding the first equation to derive the second one and confirm that if 0.5(3I - B) multiplied by B simplifies to the identity matrix, it confirms the inverse. The conversation concludes with the user gaining clarity on how to approach the problem with their specific values for B, p, and q.
Peter G.
Hi,
1.Show that B satisfies the equation (B-pI)(B-qI) = 0
2.Hence, or otherwise, show that B-1 = 0.5(3I - B)
In these kind of questions I don't know what they are testing me for! Let's take the first one as an example: The only skill they can possibly try to asses is whether I know how to multiply the matrix I by values I found previously (p and q). Other than that, all I can do to "answer" the question is performing the multiplication and showing it equals zero?
For the second one it is even worst... I know how to calculate the inverse of B and when I do it does in fact equal 0.5(3I - B), but, what should I put on paper? Calculate the inverse the regular way and then perform 0.5(3I - B) and show the results are equal?
I'm not sure if I was able to convey my doubt clearly... If the problem is due to lack of information in questions 1 and 2 I can add more information or rephrase my query.
Thanks,
Peter G.
Is that all the question gives? Is B just a general nxn matrix or is it something given? (since you said you found values of p and q)
You would just need to show that B, whatever that is will make that equation zero.
For the second one, if you pre-multiply both sides B you might be able to factorize it in the form given in 1.
Yeah, B is a 2x2 matrix. So I basically just multiply everything out and show it equals zero?
For the second one you mean if I expand the first equation I can get the second one?
Thanks once again,
Peter G.
Are you given a specific matrix B and values for p and q?
Multiply 0.5(3I - B) by B for the matrix you are given (assuming you know B). If the expression simplifies to I, then 0.5(3I - B) is the inverse of B.
Hi,
Yeah, I have a specific value for both the matrix B, p and q.
I got the second one now, thanks!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
