Is This Set a Valid Subspace of R^4?
  • Thread starter Thread starter NewtonianAlch
    Set Subspace
The discussion focuses on determining if the set S = {x ∈ R^4 | x = λ(2,0,1,-1) for some λ ∈ R} is a subspace of R^4. It outlines the three conditions necessary for a subspace: the existence of the zero vector, closure under addition, and closure under scalar multiplication. The zero vector is confirmed when λ = 0, resulting in (0,0,0,0). The confusion arises in demonstrating closure under addition, where the correct addition of two vectors u and v leads to (2a + 2b, 0, a + b, -a - b), which can be factored to show it maintains the form of the original vector. Ultimately, the set satisfies the subspace criteria, confirming it as a valid subspace of R^4.
NewtonianAlch
Show that the set:
S = {x \in R^{4}| x = \lambda(2,0,1,-1)^{T} for some \lambda \in R
is a subspace of R^{4}
For the subspace theorem to hold, 3 conditions must be met:
1) The zero vector must exist
2) Closed under addition
3) Closed under scalar multiplication
1) If \lambda = 0, the vector becomes (0,0,0,0)^{T} - therefore that's the zero vector.
2) Closure under addition is what I'm a bit confused about.
If we define two new vectors, u and v and two scalars \alpha and \beta respectively.
u + v = ?
3) For closure under multiplication, isn't this obviously already closed? Heck it's being multiplied by a scalar quantity already.
Well, if u=a*(2,0,1,-1)^T and v=b*(2,0,1,-1)^T can you show u+v has the form something*(2,0,1,-1)^T? What's the something? Sure 3) is kind of obvious, but you still have to say why.
The scalar would be (a + b)
So (a + b)*(2,0,1,-1)^{T}
Shouldn't it be (a + b)*(4,0,2,-2)^{T} though ? Because if we do u + v, the vectors would add as well as the scalars.
The vectors DO NOT add as well as the scalars. a*(2,0,1,-1)^T=(2a,0,a,-a)^T. b*(2,0,1,-1)^T=(2b,0,b,-b)^T. Add them. You don't get (a+b)*(4,0,2,-2)^T, do you? This is the distributive rule with the vector part constant.
Dang, just when I thought I was getting the hang of this stuff. No, it doesn't become (4,0,2,-2)^{T}
It becomes (2a + 2b, 0, a+b, -a - b)^{T}
So that would actually be (a + b)*(2,0,1,-1)^{T} when you factor it out.
Interesting...I have to go over the notes again.
Thanks a lot for your help Dick.
No, that's not even true for numbers: av+ bv= (a+b)v whether v is a vector or a number.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
