Homemorphism between the set of circles with rational points and rectangles
praveen97uma
I am trying to solve a problem in which we need to prove that the set of all circles with rational points and radii is homemorphic to the set of all rectangles with vertices at rational points with the length of the diagonals as rational number. I am not able to figure out what the approach should be. Any help or hints to solve the problem would be deeply appreciated.
Well, if you want to show a homeomorphism, youu need to have a topology defined
on each of the two sets.
I guess you mean each circle and each triangle is a subspace of the plane. Then I guess
we could just show that each circle can be continuously deformed to a triangle, and viceversa. Maybe we can embed each circle in a triangle.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
