Choosing Normalization to Create Bell Curve with Mean 1
  • Thread starter Thread starter vaibhavtewari
    Normalization
To create a bell curve histogram from a 40*40 matrix with elements close to 1 on the diagonal and small off-diagonal elements, normalization techniques are essential. The determinants of these matrices approximate the product of the diagonal elements squared, resulting in a histogram that peaks around 0.1 with a mean of 1. One suggested method is to histogram the logarithms of the determinant values, potentially adjusting with a constant to achieve the desired mean. Additionally, using a product of the form D~Prod(1+eps.Bjj) could yield a lognormal distribution, aligning with the Central Limit Theorem on the logarithm of D.
vaibhavtewari
I have a 40*40 matrix which has elements very close to 1 on diagonal and very small off-diagonal elements.
I find determinant of many of these randomly generated matrix, determinant is roughly multiplication of diagonal matrix squared. As (.95)^40 is a small number and (1.05)^40 is a bignumber, I get a histogram that increases from zero reaches a maxima and then fall to zero when I plot all these determinant values. It has a mean of 1 but peak at around .1
What kind of nomalization should I use such that when I make histogram it looks like a bell curve with a mean of 1.
Are you using the term "normalization" to refer to a change of variable meets very specific technical requirements or would you be happy with "any old change of variable"?
You could histogram the logarithms of the determinant values. That might be bell shaped. You would probably have to add some constant to the logs to get the mean to be 1.
If you mean D~Prod(1+eps.Bjj) or D~Prod(1+eps.Bjj)^2 where B is a random matrix, that would be approximately lognormal (use CLT on log(D)).
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
