Placement of Reaction Control System on a Spacecraft
The placement of a reaction control system, such as a reaction wheel or control moment gyroscope, is crucial for effective attitude control on a spacecraft. It is generally recommended to position these units as close as possible to the spacecraft's center of mass to optimize performance. Mounting the control module at the ends of the structure could lead to increased stress on the truss and require disproportionate force application, complicating maneuverability. The International Space Station's Z1 Truss is an example of effective placement near the center of mass, allowing for balanced force distribution. Proper placement ensures efficient operation and stability during attitude adjustments.
colinshark
Suppose you have a reaction wheel or a control moment gyroscope on your spacecraft for attitude control. This would be a self contained unit, with 3-axis control. Either device utilizes the conservation of angular momentum, trading angular momentum between the unit and the spaceship frame as needed for attitude control.
http://en.wikipedia.org/wiki/Reaction_wheel
http://en.wikipedia.org/wiki/Control_moment_gyroscope
Does the placement of the reaction control unit matter? Should it be as close as possible to the spacecraft 's center of mass for the best effect?
I think that placing it on the ends would introduce too much stress in the truss. You would be trying to move the entire mass of the station using only the truss.
I agree this would have to be placed near center mass, this would be a point where it would be easiest to have an even spread of balanced forces in as many directions as possible. To place near an end would require more force applied on one side than the other.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
