What Is the Position Operator x When Momentum p Is Defined as (h/2m)½(A+B)?
  • Thread starter Thread starter qmpuzzler
    Operator Position
qmpuzzler
I'm so confused about the question below,actually i cannot understand the problem at all.Could anybody help me out?Thank you
Find the operator for position x if the operator for momentum p is taken to be (h/2m)½(A+B),with[A,B]=1,and all other commutators zero.
i just cannot figure it out how can the position,which is a opeartor itself,can have a operator for.
What is the commutation relation between x and p? How can you construct x to satisfy that commutation relation?
Here is the question:
Honestly,i have no idea what is the meaning of the question.
QMPuzzler, just as a hint to what you were asked by the original helper, I think you might want to consider how the commutation relations work, for example: [x,p] = xp-px.
Thanks,but still have no clue in solving.can you explain how to work it out?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
