Trouble understanding Circular Motion(Uniform and Nonuniform) concepts
  • Thread starter Thread starter craigerymonto
    Circular Concepts
Understanding circular motion involves grasping key concepts such as uniform and non-uniform motion, where uniform circular motion features constant angular velocity but changing linear velocity due to constant direction change. In uniform circular motion, acceleration is always present and orthogonal to velocity, while angular velocity relates to circular motion similarly to how linear velocity relates to straight-line motion. Questions about forces acting on a rigid object in motion and the relationship between points on that object can clarify these concepts. Engaging with specific questions can aid in understanding the formulas and principles involved. Mastering these foundational ideas is essential for further study in circular motion.
craigerymonto
Hey,
My professor introduced circular motion this last Friday in his lecture and I've spent the weekend trying to figure out the basic concepts behind it as well as the different formulas that are used. I've had a lot of trouble with this and any help would be appreciated.
You need to get a bit more specific before anyone decides to start explaining anything.
Maybe if you would say exactly what concept/formula you don't quite understand and why you don't understand it or what it is you think it is, etc.
A few simple concepts should help get you started:
constant velocity is movement in a straight line and uniform speed,
uniform circular motion therefore involves acceleration as direction (of velocity) is constantly changing as rotation occurs,
in uniform circular motion acceleration is always present and the acceleration (vector) is orthogonal to the velocity (vector),
angular velocity w is to circular motion as velocity v is to straight line motion,
with a rigid rotating object, each point out from the center of rotation moves at the same angular velocity w but an increasing linear velocity [ v= wr].
And it always helps I thionk to ask yourself some questions and see if you can answer them:
maybe,
where on a rigid object in uniform circular motion are forces greatest?
If I twirl a stick from the middle, and the tip moves at "a" ft/sec, how fast is it moving half way from the tip??
Which of the following is constant on a solid rigid disc in uniform circular motion?:
a]velocity,
b]acceleration,
c]angular velocity,
d]all of the above,
e]none of the above
etc, etc
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
