Find the at which value does the 1/(1-6sinx) is discontinous
  • Thread starter Thread starter kougou
    Value
The function 1/(1-6sinx) is discontinuous when the denominator equals zero, specifically at 1-6sinx=0, leading to x=arcsin(1/6). The discontinuities occur at x=arcsin(1/6)+2πn and x=π-arcsin(1/6)+2πn due to the periodic nature of the sine function. The arcsin function is restricted to the interval [-π/2, π/2], but sine itself has solutions in both the first and second quadrants. The addition of 2πn accounts for the periodicity of sine, allowing for multiple solutions. Understanding these concepts clarifies the reasoning behind the discontinuities of the function.
kougou
so, find the at which value does the 1/(1-6sinx) is discontinous
so, it's discontinous when the bottom is equal to zero, which is 1-6sinx=0
solve for x, which give arcsin(1/6).
and now, the correct answer is x is not = arcsin(1/6)+2pi n
and x is not = pi-arcsin(1/6)+2pi n
the bold part is where i don't understand. what? the arcsin has a period of 2pi? did we already restrict it to -pi/2 to pi/2?
what? how come the answer lays on the second quadrant? shouldn't it be lay either in first or the fourth quadraint?
what? how come the we ignore the third quadrant?
don't get it. need help
1-6*sin(arcsin(1/6)+2*pi*n) is equal to zero isn't it? sin is periodic with period 2pi, arcsin doesn't have to be.
Hello
yes, sin is periodic, but why we add 2pi n at the end, and why we subtract that from pi. I don't get it. is there a way to derive this?
kougou said:
Hello
Look at a graph of sin(x) on [-pi,pi]. There are two values of x where sin(x)=1/6, yes? One is arcsin(1/6). The other is pi-arcsin(1/6). You can read those off the graph. Now you can add 2*pi*n to either one since sin is periodic.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
