Understanding Gaussian Beam Contraction and Divergence in Optics
The discussion revolves around understanding Gaussian beam behavior, particularly contraction and divergence. The q parameter's expression indicates that the beam's width, w(z), decreases to a minimum at the beam waist before expanding again, which can occur naturally or with the aid of lenses. The propagation of a collimated beam leads to inevitable expansion, while certain configurations, like Fabry-Perot lasers, can result in beams with decreasing diameters. Additionally, the use of complex functions in optics, such as psi(x,y,z)exp(-jkz), is emphasized for accurately representing beams with non-uniform intensity profiles and varying phase fronts. Overall, the conversation seeks to clarify the mathematical and physical principles behind these optical phenomena.
zebanaqvi
I am new to lasers. In the expression for q parameter, 1/q = 1/R - j(λ/πw^2)
how did we come to know that w(z) is a measure of decrease in field amplitude E with distance? I can't feel it.
Does the gaussian beam itself contract to the minimum diameter? Shouldn't a lens be required for this? I can understand the divergence of the beam but not the contraction.
Can anybody please make me understand both mathematically and physically?
Regards,
Zeb
if you "start" with a collimated beam, then it will always expand in diameter.
but sometimes for a variety of reasons you can get a beam that will have beams with decreasing diameter as it propagates until it forms the beams waist and start to expand again.
Such beams are easily created, like you said, with lenses. fabry-perot laser beams sometimes come with a decreasing diameter probably due to the non linearity of the components in the resonator.
does that answer your question?
Thanks a lot :)
Sorry, what I am about to ask might be lame.
I have the helmholtz equation, and I want to solution to represent a beam whose phase front is not plane always, whose intensity profile is not uniform across the cross section. What function should I try out? You'll say complex. Something like psi(x,y,z)exp(-jkz) where psi is a complex function. Please explain me why should psi be complex? Is it that only a complex function will be able to represent the desired beam? y?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
