Energy in the Magnetic field of a moving point charge, simple question
The discussion revolves around the energy stored in the magnetic field created by a moving point charge, focusing on the relationship between this energy and the speed of the charge. Participants explore theoretical approaches, mathematical formulations, and the implications of classical versus quantum mechanics.
  • One participant seeks to determine the energy stored in the magnetic field as a function of speed, proposing a formula based on magnetic field energy density.
  • Another participant suggests treating the point charge as a piece of current and applying the Biot-Savart law to find the magnetic field, noting the challenge of integrating over all space due to singularities.
  • A question is raised about what constitutes a reasonable lower limit for the region of integration, with suggestions including very small values and the Bohr radius.
  • One participant highlights the breakdown of classical theory near the particle and suggests that the energy dependence on speed is likely proportional to v^2, while also acknowledging potential quantum mechanical considerations.
  • Another participant emphasizes the inadequacy of classical models for point particles, discussing the divergence of total energy in the electric Coulomb field and the complexities introduced by acceleration and radiation damping.
  • Links to external resources are provided, with one participant expressing that the material may be advanced for their current understanding but aligns with their inquiries.
  • A later post introduces a speculative idea about the nature of charge and energy distribution, drawing on metaphors and personal interpretations without clear scientific backing.
Participants express a range of views on the topic, with no consensus reached regarding the specific relationship between energy and speed or the appropriate methods for calculating it. The discussion includes both classical and quantum perspectives, highlighting ongoing uncertainties and complexities.
Participants note limitations related to the use of point charges in classical physics, the divergence of energy calculations, and the need for careful consideration of integration limits. The discussion reflects a blend of classical and modern physics concepts without resolving the underlying issues.
elegysix
I'd like to know what the energy stored in the magnetic field created by a moving point charge is, as a function of speed. Hopefully, someone knows a relationship like this? or how to get this? I've got a straightforward approach below, but don't know how to integrate it.
BfieldEnergy = f(|v|)
For low constant speeds, not worried about direction, so just the magnitude of v... not worried about relativistic effects either, and let's assume its not accelerating.My best guess is use u=B^2/2mu0, where B is given by (mu0/4pi)*e(vXr(hat) )/r^2, and integrate that from r = 0 to infinity... but I don't know how to handle the r=0, the integral just explodes... there must be some limit or something. Anyways, I'm guessing the relationship is proportional to |v|^2, but if you know or can figure it out I'd really appreciate it.
thanks
austin
If you don't care about accelerations or relativistic effect, you can treat the point charge as a piece of current, I dl = v dq. Put this into the Biot-Savart law find the magnetic field due to this "current", than plug this field into u=B^2/2mu0 to find the field energy density.
Yes, the total field energy is the integral over all space of the field energy density, but you can't really do this integral over all space when using unphysical idealizations like a point charge, because the fields blow up like you said. It is better to define a region not including the singularities and find the total energy just in that region.
What would be a reasonable guess for that region approximation? .1, .01, ... 0.0000001? the bohr radius?
This is an interesting question, and I'm not sure of the answer. The classical theory breaks down when you get very close to the particle, and quantum mechanics is the 'correct' theory to use.
So yes, maybe you should use some lower limit for the values of r to be integrated over. You'll find the energy then depends on this lower limit for r. But you're not interested in that, right? You're interested in the speed dependence.
The speed dependence would be v^2, as you guessed. This is the speed dependence for the macroscopic energy. For the quantum limit, there is probably some other dependence..
This is a very deep issue and cannot be answered adequately by postings in a forum. The total energy of a charged classical point particle is not well defined, since already for a point particle at rest the total energy in its electric Coulomb field diverges.
On the other hand, for point particles, classical models do not make any sense. So one has to go to extended objects and define the field energy. However, even this is not so easy in a covariant way. The modern definition is to define the total field energy for the particle at rest (which is electrostatic and/or magnetostatic if there's an intrinsic magnetic momentum, e.g., for a permanent magnet). Then you Lorentz boost the whole system and get the total energy-momentum vector of the electromagnetic field.
If it comes to acceleration of the particle/body it's even worse. Then you have the problem of radiation damping, i.e., the interaction of the particle with its own electromagnetic radiation field, and that's indeed a very delicate issue. The best treatment of the problem is given in the textbook
F. Rohrlich, Classical charged particles 3rd ed., World Scientific
carelvanderto said:
Maybe you find your answer at www.paradox-paradigm.nl
Regards
Thanks for that link, it is much advanced beyond my skill of thinking, but sounds as if many questions I have are inline with the general trend of what it implies.
With much to consider, I have the thought of the charge of the electron is the ether, and that the collapse rate is less than the speed that creates it. Think about the long strand of silk, spun into a cocoon.
A core-less transformer, that moves energy at different rates because of variation in radius of lines of force, to any reactive particle in the area. No loss of energy, but a redistribution.
Based on recent study, I'm sure that wiki already covers all this, just in better form. Sigh...
Ron
  • · Replies 17 ·
  • · Replies 26 ·
  • · Replies 26 ·
13K
