What is the tension in the offset wires for a horizontal steel beam?
  • Thread starter Thread starter prokser
    Tension Wires
To determine the tension in the right cable supporting a 35kg, 5m horizontal steel beam with one cable at the left end and another 1m from the right end, moments should be taken about the point where the left cable is attached. The calculation involves balancing the moments created by the beam's weight and the tension in the right cable. The user initially struggled with the concept of offset wires but found clarity by focusing on moment calculations. The solution was ultimately achieved with this approach. Understanding the mechanics of tension in offset wire systems is crucial for accurate calculations.
prokser
a uniform horizontal steel beam of mass 35kg and length of 5m is supported by two vertical cables. the first attached at the left end and the second 1m from the opposite end. find the tension in the cable on the right.
n=mgsin0
I have no idea how to do this with offset wires. if they were both on the end it would be easier.
You can start by taking moments about the end where there is one of the cables attached.
I solved it. Thanks!
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
