Constructing a hall effect transducer
Constructing a Hall effect transducer without p-type semiconductors is challenging due to the reliance on materials like gallium arsenide and indium antimonide in commercial sensors. The Hall effect generates a potential difference across a conductor with current in a magnetic field, but metals have high electron concentrations, resulting in very small Hall voltages that are difficult to detect. Theoretical calculations indicate that achieving a measurable Hall voltage would require significant current and strong magnetic fields, which may not be feasible in practical applications. The discussion highlights the importance of understanding charge carrier density and its impact on Hall voltage. Overall, while theoretically possible, practical implementation without p-type materials poses significant challenges.
tummychow
Is it possible to construct a hall effect transducer without the use of p-type semiconductors? I've been looking into the fundamental design of a hall effect sensor, and it generally comprises some amplification/thermal control bits and pieces that all are bound to the most important part, the hall element itself. I'm familiar with all the little bits from other work. But I need the element first.
Commercial hall effect sensors employ elements made out of superthin wafers of p-type semiconductor, from what I've seen. Gallium arsenide and indium antimonide are the norm in the industry (again, from what I've seen). However, I definitely do not have access to these materials.
From a theoretical standpoint, the Hall effect creates a potential difference across any conducting plate that has a current running across it. However, theory often fails to translate into reality. I am seriously in doubt of the idea that I could use any old metal plate, scrub it down, and pipe a current across it to observe the Hall effect (in at least a response of tens of microvolts, which could be amplified with an ultralow offset opamp like an OP07). Is this possible, or (as I suspect) am I spouting impossibilities?
PS: My theoretical knowledge is running a bit short here since I'm not quite sure how to analyze the hall response theoretically (which would let me figure out if building my own hall element was possible), when I don't know how to analyze the charge carrier density theoretically. Wikipedia tells me that the carrier density is usually determined by analysis with the Hall effect >_> not very useful for this problem. Theory of charge carrier density is a question for another time though.
The hall voltage is the result of an electric field caused by the deflection of electrons (the current) when a conductor is in a magnetic field.
The force due to the electric field is equal to the force due to the magnetic field.
Analysing this equality give the equation for the HALL VOLTAGE :
Vh = (BxI)/(net)
where B = Magnetic flux density (T)
I = current (A)
n = electron concentration (electrons per m^3)
e = electron charge (1.6 x 10^-19C)
t = thickness of sheet
With metals the electron concentration is high ≈ 10^29 and this means that the Hall voltage is small and therefore difficult to detect.
If you make I = 1A, B= 10T and t =1mm (1 x 10^-3 m) and substitute these you should see that you get about 1μV.
Semiconductors are used in practical Hall effect probes because they can be made with a very small free charge carrier concentration and therefore give a larger Vh
First off, thanks for the quoted number on charge carrier density. that helps a lot. I guess I would have to pass through a ton of current to make the effect more visible? I don't think I'm going to be dealing with magnetic fields that strong. (probably on the order of magnitude of 0.00002T or possibly even less)
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
