Difference Between Spatial and Temporal Frequency Decomposition of Waves?
Niles
Hi
In Griffiths it is stated that any possible wave can be written as a sum of plane waves
<br /> f(z,t)=\int_{-\infty}^{\infty}{A(k)e^{i(kz-\omega t)}dk}<br />
This is a sum over spatial frequencies. In another book I have, they write the H-field as
<br /> H(r, t) = \sum_n{C_n H_n(r)\exp (-i\omega_n(t-t_0)}<br />
where Cn are the amplitudes. This is a sum over temporal frequencies (i.e. ω, not k) of monochromatic waves. What is the difference between expressing an arbitrary wave in terms of frequency and spatial components? Is the answer that there is no difference, since (because of dispersion), when I vary k I also automatically vary ω and vice versa?Niles.
Homework Equationsf(z,t)=\int_{-\infty}^{\infty}{A(k)e^{i(kz-\omega t)}dk}H(r, t) = \sum_n{C_n H_n(r)\exp (-i\omega_n(t-t_0)}The Attempt at a SolutionNo attempt at a solution has been made.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
