Find grams of product using a balanced chemical equation
The balanced chemical equation shows that 2 moles of potassium chlorate (KClO3) decompose to produce 2 moles of potassium chloride (KCl) and 3 moles of oxygen (O2). To find the grams of potassium chloride produced from 25 g of potassium chlorate, the calculation involves converting grams of KClO3 to moles, then using the stoichiometric ratio to find moles of KCl produced, and finally converting back to grams. The correct calculation yields approximately 15.2 g of KCl, confirming the final result is accurate despite missing a crucial stoichiometric conversion factor. The stoichiometry indicates that 2 moles of KCl are produced for every 2 moles of KClO3 decomposed, which simplifies to a 1:1 ratio.
trivk96
2KClO3 → 2KCl + 3O2
How many grams of potassium chloride are produced if 25 g of potassium chlorate decompose
25g * (1 mole KClO3/122.45 g KClO3) *(74.45g/ 1 mole KCl) =15.2 g KCl
is this right??
Final result is OK, although you are missing a conversion factor, one that is crucial for the stoichiometry - 2 moles KCl produced per each 2 moles of KClO3 decomposed. Luckily to you 2/2 is just 1.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
