I have to start with some book but wich collection is better
  • Thread starter Thread starter hagopbul
    Book
When deciding between the Walter Greiner and Landau & Lifgarbagez collections, it's important to consider your background as a first-year master's student. Landau & Lifgarbagez is noted for its clear language but is concise in mathematical expressions, requiring readers to fill in some derivation steps. In contrast, Greiner provides more detailed steps but may be less well-written, with concerns raised about the quality of its English translation. It is recommended to access both collections from the library to determine which aligns better with your learning style. The consensus suggests starting with Landau & Lifgarbagez before moving on to Greiner.
hagopbul
i have the following collections and i want to know with what should i start reading the Walter Greiner or Landau L.D., Lifgarbagez E.M collection?
I'm not familiar with Greiner, but Landau and Lifgarbagez is not a beginning text, so it depends upon your background.
1st year master degree student
You should probably get both at the library and find out which one suits you better. My short opinion on them: Landau has very clear language, but in very concise in the mathematical expressions, leaving many steps in derivations to you. Greiner fills in more of the steps, but may be less well written. I have also read bad things about the english translation of Greiner, which I can't comment on since I only used his german books.
thank you i will start with L then G
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
9K
