Electrolysis Products: NaCL vs MgCL: 9th Grader's Science Fair
  • Thread starter Thread starter esaltzman
    Electrolysis
A 9th grader is conducting a science fair project comparing the hydrogen gas production from NaCl and MgCl during electrolysis. After one hour of applying a 2.5 amp current, the NaCl solution produced a brownish residue, while the MgCl solution turned milky white. The brown residue is likely a copper compound formed from the copper electrodes, while the milky appearance in the MgCl solution suggests the formation of a precipitate, possibly related to magnesium. Further investigation into the chemical reactions and compounds formed during electrolysis is recommended. Understanding these reactions will enhance the project's insights into electrolysis and Faraday's law.
esaltzman
I am a 9th grader working on a science fair project to determine which salt, NaCL or MgCL produces the most hydrogen gas through electrolysis. I used 1.5 ml of water for each, and 17.5 mg of each salt respectively. After 1 hour of applying a 2.5 amp current through each sample, the NaCL solution formed a brownish residue, while the magnesium chloride solution had turned milky white. What reactions had taked place, and what were the product(s)?
P.S. The wires in the water were copper.
Chemistry news on Phys.org
sure it 1.5ml of water?
You do not state what voltage .
Nonetheless,
NaCl solution
You have ions H+, Na+, Cl-, and OH- in solution
The electrode is copper and that can form oxidatin states of +1, +2, +3, +4
You know that the other ions can form compounds but not with a brown color,
so the brownish residue is some sort of copper compound assuming only +1, +2 oxidation
It could be CuOH, CU (OH)2, , Cu2O, CuCl, Cu Cl2
Does that help you out?
Thanks so much! Have any thoughts on the MgCl2 solution?
Do the same thing for the MgCl2 solution.
When the solution is prepared, what species are present in solution.
Then, as the electrolysis is performed what compounds have a possibility of being formed.
Of those compunds, what forms a milky white precipitate suspended in the water, but most likely something to do with Mg.
Note that for the NaCl solution you still have to decide which one compound has formed the browniish residue, instead of a brownish liquid, which since you say residue is not soluable in water.
You still have some more research to do.
Come back if you have some more questions.
Sorry if I appear to be vague but you trying to find out what the precipitates are will give you tremendous insight into chemical reactions.
Do you know Faraday's law of electrolysis?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
