Medical Cuffles blood pressure measurement regression equation
The discussion centers on the application of a regression equation from the paper "Continuous measurement of systolic blood pressure using the PTT and other parameters." The equation suggests a linear relationship between systolic blood pressure (BP) and factors such as pulse transit time (PTT), weight, and arm length. However, users report obtaining implausible BP values when applying the equation. There is confusion regarding the relationship between PTT and BP, as PTT is typically inversely related to blood pressure, raising questions about the inclusion of weight and arm length as variables. Additionally, the relevance of measuring arm length versus the distance between pulse measurement points is debated. The article's goal is to provide a non-invasive method for measuring systolic pressure without the need for calibration or cuffs, but it does not compare this method with traditional blood pressure measurement techniques.
fonda99
Has anyone tried to apply the following regression equation appeared in the paper "Continuous measurement of systolic blood pressure using the PTT and other parameters" (Proceedings of the 2005 IEEE Engineering in Medicine and Biology 27th Annual Conference Shanghai, China, September 1-4, 2005):
SystolicBP = 85.862 -119,27 PTT +0.259 weight + 0.439 arm length
(Blood pressure in mmHg, PTT is Pulse Transit Time[ms], weight[Kg], arm length[cm])
Nice linear relationship but I get absurd values for BP.
Any help is greatly appreciated.
Biology news on Phys.org
I had never heard of it before, and had to look up what pulse transit time is. Other reputable sources refer to it as directly proportional to blood pressure, but if that's the case, then factoring in weight doesn't make sense. I also suspect it ought to then not be arm length, but the distance between the two pulse points being used to measure PTT. For example, if you're measuring transit time between brachial and radial pulses, it might matter the length of the forearm, not the arm. It seems to me that it would be more difficult to accurately measure PTT than BP. Did the article offer any reason to choose one method over the other?
Oops, sorry for lack of infos.
Pulse transit time is the time interval between the R peak of electrocardiogram (ECG) and the systolic peak of the signal recorded through the photoplethysmograph at one finger (the signal is created by the sensor which detects the reflectance variations of an illuminating infrared beam in the finger). Larger the pressure, smaller the pulse transit time (PTT), so it is inversely related to blood pressure. The article doesn't compare the method with other methods; its aim is to introduce a method to avoid blood pressure calibration and cuff usage, to measure systolic pressure of any subject in a non intrusive way.
https://www.nhs.uk/mental-health/conditions/body-dysmorphia/ Most people have some mild apprehension about their body, such as one thinks their nose is too big, hair too straight or curvy. At the extreme, cases such as this, are difficult to completely understand. https://www.msn.com/en-ca/health/other/why-would-someone-want-to-amputate-healthy-limbs/ar-AA1MrQK7?ocid=msedgntp&cvid=68ce4014b1fe4953b0b4bd22ef471ab9&ei=78 they feel like they're an amputee in the body of a regular person "For...
Thread 'Did they discover another descendant of homo erectus?'
The study provides critical new insights into the African Humid Period, a time between 14,500 and 5,000 years ago when the Sahara desert was a green savanna, rich in water bodies that facilitated human habitation and the spread of pastoralism. Later aridification turned this region into the world's largest desert. Due to the extreme aridity of the region today, DNA preservation is poor, making this pioneering ancient DNA study all the more significant. Genomic analyses reveal that the...
Whenever these opiods are mentioned they usually mention that e.g. fentanyl is "50 times stronger than heroin" and "100 times stronger than morphine". Now it's nitazene which the public is told is everything from "much stronger than heroin" and "200 times stronger than fentany"! Do these numbers make sense at all? How do they arrive at them? Kill thousands of mice? En passant: nitazene have already been found in both Oxycontin pills and in street "heroin" here, so Naloxone is more...
