Equivalent definition of the supremum
The discussion centers on the definition of the supremum of a set M, specifically whether the condition "y >= x implies there exists m in M such that m >= x" is equivalent to y being the supremum of M. It is argued that this condition is not true, as demonstrated by counterexamples where y equals x. The participants suggest modifying the condition to "y > x implies there exists m in M such that m >= x," which is confirmed to be correct. This revised definition aligns better with the properties of the supremum. The conversation concludes with agreement on the validity of the modified definition.
submartingale
Hello everyone,
is the following an equivalent definition of the supremum of a set M, M subset of R?
y=sup{M} if and only if
given that y is an upper bound of M and x is any real number,
y >= x implies there exists m in M so that m >=x.
pf:
Let x_n be a sequence approaching y from the right. Then
for each x_n, there exists m_n in M so that m_n >=x_n.
Since y is an upper bound of M, then we have that y= lim m_n >= lim x_n.
Therefore, if m' is any another upper bound, then m'>=y for all m in M.
Thanks
Mathematics news on Phys.org
This is not true. Specifically, if y=sup(M), then it does not need to holds that y>=x implies m>=x for an m.
Indeed, take y=x.
Indeed, take y=x.
If you take y=x, then there exists m in M so that m>=x=y. But y is an upper bound of M, so y=x=m.
Take A=]0,1[, then y=1 is a supremum. Does there exist an m in A such that m>=y??
What if we replace it by
y >x implies there exists m in M so that m >=x.
Thanks
Thanks
That's indeed correct.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
