Striking the End of a Triangle in Space
  • Thread starter Thread starter harrietstowe
    Space Triangle
harrietstowe
http://img221.imageshack.us/img221/4861/figure1h.png
Mod note: Fixed the image link.[/color]
Consider the rigid object shown in this image. Four masses lie at the points shown on a rigid isosceles right triangle with hypotenuse length 4a. The mass at the right angle is 3m, and the other three masses are m. They are labeled A,B,C and D as shown. Assume that the object is floating freely in outer space. Mass C is struck with a quick blow, directed into the page. Let the impulse have magnitude ∫F dt = P . What are the velocities of all the masses immediately after the blow?
The one given in the problem statement
v=ω x r
Torque = r x F
ΔL=r ΔP
I think computing the CM of this system would be a good place to start. I think I need to use the angular impulse formula but I'm wondering which mass I should go after first. My intuition leads me to believe the velocity of mass A will be opposite that of mass C. Is this all reasonable?
hi harriet! :smile:
that's right …
impulse = mtotalvc.o.m :smile:
don't assume anything, it's too dangerous
just find the initial angular velocity, then add the effect of that (on each mass) to the vc.o.m :wink:
ok so let position of the CM be R and let's work in the x y z coordinate system
Then R=[m(0,0,0)+m(2a,0,0)+m(4a,0,0)+3m(2a,2a,0)]/6m
which simplifies to
R=((4/3)a,(1/3)a,0)
Then using the equation Impulse=(mtotal)(vcm) we can write:
P=(6m)(vcm)
vcm=p/6m
Now to find the initial angular velocity ω I can write:
vcm=ω r
for r though do I use the distance from the cm to mass C?
In that case I would have:
P/6m=ω (a/3)(√65) and so
ω=P/(2(√65)a m)
which simplifies to
R=((4/3)a,(1/3)a,0)
nooo :redface:
you've used m instead of 3m
anyway, it would be much easier in this case to say that the c.o.m. of the bottom three is obviously 3m in the middle, and then the c.o.m. of that and the top one is equally obviously 6m halfway up the middle :smile:
(and why do you keep saying "cm"? there's nothing about cm in the question)
P=(6m)(vcm)
vcm=p/6m
vcm=ω r
ω=P/(2(√65)a m)
no, you need to use moment of impulse = change in angular momentum
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
