Does Centripetal force cause a tangential force?
Centripetal force is responsible for maintaining circular motion, calculated using F = m(v^2/r) or F = m r ω^2. A tangential force only exists if there is tangential acceleration present. When angular speed is constant, no tangential force acts on the mass. Therefore, in uniform circular motion, the absence of tangential acceleration means no tangential force is present. Understanding these dynamics is crucial for analyzing forces in circular motion.
Kalus
If I have a string with a lump on the end and is being swung in a circle with a continuous angular velocity then I know that:
F= m\frac{v^2}{r}
or using angular velocity,
F= m r \omega^2
But, is there a tangential force acting at the point of mass in its instantaneous direction, and if so, what is it equal to?
Hi Kalus! :smile:
("/tex" not "\tex" :wink:)
There's a tangential force only if there's a tangential acceleration (Newton's second law).
If the angular speed is constant, there isn't.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
