Basic Statics - A weird outcome. Contradictory?
  • Thread starter Thread starter Femme_physics
    Statics Weird
The discussion revolves around the static friction coefficient and its implications in mechanics. A scenario is presented where a beam's static coefficient is 0.3, leading to calculations that suggest the beam does not slide. The user questions the validity of applying the static friction formula Fs = N x μ without considering maximum static friction, leading to confusion about the normal force. It is clarified that the static friction force adjusts to maintain equilibrium and that the coefficients represent maximum values reached only at the verge of movement. Ultimately, the conclusion emphasizes that the static friction force is not equal to the product of the coefficient and normal force unless movement occurs.
Femme_physics
This is not a HW question! THIS IS A DISCOVERY that I want to explore. I will explain it as follows:
Suppose I have this exercise, where I know the static coeffecient between the beam and the floor is 0.3, whereas in the wall there is no friction. I want to find out if the beam slides, or stays up. That's easy.
http://img703.imageshack.us/img703/4676/fsmaxtest.jpg
So by doing the calculations, I can see the beam doesn't slide. I solved the problem. Now, let's say I want to experiment further. What happens if I put the result of Fs I got when I didn't calculate Fs_max into the Fs = N x μ equation? I think it's a valid thing to do, since it's in the formula. But what happens then?
I'd get a different result for N. Which doesn't make sense, since N must be 30 [N] to resist the weight of the beam.
The friction coefficient sure can't change, since it is constant!
So, what did I just do? Did I find loop in mechanics theory?
Not valid. If the surfaces were moving, you could use such a formula. In case of static objects, we can only get the maximum friction force.
When we are standing on the floor, there is a normal equal to our weight W . The surface has a μ too. Does it mean we are experiencing a horizontal force of μW on our shoes?!
Of course not. We don't feel friction without moving in the axis it exists.
How come?
If you recall
http://img62.imageshack.us/img62/7107/frri.jpg
So clearly either the friction coeffecient or the normal force haven't reached their max value. One of them must change. Since it can't be the normal force, as that would defy mechanics, it must be the coefficient: This is my new assumption. The coefficients we see in charts therefor are maximum values. We reach that maximum value of that coefficient only on the verge of movement.
How about that for theory?
You will get the minimum N needed to prevent sliding due to Fs.
No, it has nothing to do with the actual N.
Yes, the static friction coefficient tells you the maximal horizontal force for a given normal force, for a static case.
Obviously.In every decent book I read,
they clearly state that Fstatic≤μstaticN
and NOT FstaticstaticN
That is,the friction force adjusts itself to keep the concerned body in equilibrium.And the maximum it can be in order to negate the applied forces is given by μstatic times N.
So the coefficient remains constant,but the maximum force of static friction,ie μstaticN is experienced only on the verge of the movement.
Got it sorted out. Thanks :)
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
