Electric field inside a void in a conductor?
The electric field inside a conductor and any voids within it is generally considered to be zero, supported by Gauss's Law, which states that the field is zero when there is no enclosed charge. However, the assumption of a zero field is an approximation, as there are no truly perfect conductors, and advancements in nanotechnology may challenge this understanding. The discussion highlights that while the spherical shell example illustrates the principle, arbitrary geometries require different methods for analysis. The conversation also touches on the implications of superconductors in this context. Overall, the topic emphasizes the need for further exploration of electric fields in various conductor shapes and conditions.
Hassan2
Hi everyone,
The field inside a conductor and also inside any voids in a said to be zero. I'm convinced with the available proofs for the field inside a conductor. However, I am not aware of any solid proof for the field inside a void in a conductor. Would you please share your knowledge on this topic?
Thanks.
Hassan2 said:
Hi everyone,
Thanks.
There's no such thing as an unconditionally perfect conductor. The zero field assumption is only approximate. It will be even more suspect when science furthers develops nanotechnology, rendering these approximations as a quaint symbol of the time when people didn't need to care about it.
If I have a spherical shell with plus q charge on it, the E field is zero inside because there is no enclosed charge so it is zero by Gauss's Law.
no perfect conductors, what about superconductors?
That's based on the symmetry of the shell. For an arbitrary geometry we need another approach.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
