How Does Melting Temperature Affect the Density of Vacancies in Copper?
  • Thread starter Thread starter Arran
    Density
Arran
Consider a crystal of copper with the f.c.c. structure. Suppose the energy costs for creating a one-atom vacancy in the material is 1.1eV. The melting temperature of the material is 1356K. Estimate equilibrium density of vacancies in the material.
NV/NL=exp(-Δhf/kT)
where NV is the number of vacancies,
NL is the number of lattice sites,
Δhf is the energy required to create a one-atom vacancy,
& k is boltzmann's constant
Equilibrium density of vacancies = NV/NL=exp(-Δhf/kT)=
=exp(-1.1*1.6*10-19/1.38*10-23*300)=3.45*10-19
I think I understand the equation and am able to derive it. However, I don't understand the relevance of the melting temperature. I assume the "equilibrium" implies room temperature, so I use T=300K. Also I don't see the relevance of the crystal structure, f.c.c.
Please help me. I feel as though I am missing the point of the equation :)
I'm pretty sure for T you are supposed to use the melting point of copper i.e 1357.77K.
But the formula implies (to me anyway) that the density of defects is temperature dependent, which makes sense. So as T goes to zero, so too does the density of defects. As T goes to infinity, the defect density goes to unity.
My only idea about the melting point is that at this temperature (T=1357.77K) the density of defects somehow saturates or reaches unity or some such. I don't see how to describe this with the given equation though. . .
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
