What's it called when a 3D shape can be made of 2D surfaces of all the same size
keysle
What's it called when a 3D shape can be made of 2D surfaces of all the same shape and dimensions?
To make a cube, I can use 6 4-sided-squares (of course they're 4 sided)
To make a pyramid (3 sided), I can use 4 3-sided-triangles
I can do this with pentagon as well (i don't know what the shape is called)
Eventually I can't do this as the sides of the shape increase because the remaining angle.
... after some thinking I realized I can only do this with 3 equilateral shapes.
3 sided
4 sided
and 5 sided
Once I get to the hexagon ... well
Now here's an even more interesting question: Are there any others shapes convex or concave equilateral or not that can be used to create a 3D shape? (where the base shapes remains the same)
If so how can one determine if a shape is capable of doing this?
Regular polyhedron
Thanks!
Doesn't look like there are too many of those shapes.
Do you know about the second questions?
3 sided
4 sided
and 5 sided
You can use the Euler Formula to prove, if I remember correctly, there are only five which are all regular polygons. 4,6,8,12,20
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
