Lead-Lag Compensator: Band-Pass Filter
  • Thread starter Thread starter CognitiveNet
    Compensator Filter
A lead-lag compensator is primarily viewed as a low-pass filter, which limits its ability to amplify high frequencies due to energy constraints. However, it can be designed to exhibit band-pass characteristics by adjusting the frequencies of its zeros and poles, allowing for gain in specific frequency ranges. The discussion highlights that while lead compensators can amplify high frequencies, the overall design must consider energy requirements to avoid component failure. Additionally, the combination of lead and lag elements can create a system that boosts signals between certain frequencies while attenuating others, effectively functioning as a band-pass filter. Thus, the assertion that a lead-lag compensator cannot act like a band-pass filter is not entirely accurate.
CognitiveNet
My professor in Feedback Control Systems told me that a lead-lag compensator is basically a low pass filter and that you can't amplify high frequencies because it requires a lot of energy. Thus, you can't design a PID/lead-lag compensated transfer function which acts like a bandpass filter. Is this correct?
Based on this assumption, I've come up with a theory: In my laboratory, I've built an infrared transmitter and receiver with an RLC as its bandpass filter. The receiver isn't working and no other engineers have been able to make it work. So according to what my professor told me, is this because the power supplied isn't sufficient? (If the voltage was any higher, the op-amps would burn up.)
The circuit is shown in the website bellow;
http://howcircuits.com/active-ir-motion-detector.html
I recently discovered something interesting that might support what my professor stated:
"If you attempt to set ωCO1 to a higher frequency than ωCO2, the band-pass filter will block all frequencies, and no signal will get through."
http://www.play-hookey.com/ac_theory/band_pass_filters.html
Another proof that he is right:
The lead compensator offers PD control. This causes it to speed up the response of a system.
With a lead compensator high frequencies are amplified.
The PI controller reduces high-frequency
noise. As such, it can be used as a low-pass filter
The lead-lag compensator combines the lead and the lag compensator.
http://aerostudents.com/files/automaticFlightControl/adjustingSystemProperties.pdf
So from this I assume it is just a compensated low-pass filter.
that doesn't sound quite right.
They have transfer function of form ## \frac {T1s +1 }{T2s+1} ##
so can have ac gain depending on ratio of lead & lag times.
The Bode plot shows how they'll respond to a frequency sweep.
Here's an article on them:
http://www.library.cmu.edu/ctms/ctms/extras/leadlag.htm
And here's a powerpoint show that has some nice graphics.
It'll open with Microsoft's free Powerpoint viewer or OpenOffice.
http://www.google.com/url?sa=t&rct=...w5WeCA&usg=AFQjCNGrLxwH3bEqljE0CW2RjzOBQwuHSg
hope this helps. (I'm no expert)
Lead-leg compensators have different frequencies for the zero and the pole. Based on the difference of the two frequencies we get different static gains below the lower frequency and above the higher frequency.
For example, a widely used PI compensator has a pole at the origin and a zero at a non-zero frequency. A lead-lag compensator cannot achieve zero steady-state error as it by definition has non zero pole location.
Also, consider a lead-leg with zeros at 1 and 100000 radians and poles at 100 and 1000 radians. You will get a boost between the two zeros and attenuation elsewhere, which is pretty much a bandpass filter.
The P, PI, PD, PID, lead and lag complement each other (some are special cases of other ones).
So you are assuming that a high pass filter can be made with a lead-lag system?
What about the energy requirements, is it very high?
How about a lead compensator that has a zero at -1, a pole at -10 rad, and Kp = 0.1? (i like to use the Kp*(1+s/wz)/(1+s/wp) formula as it gives negative pole locations -> stable systems). Though any formula will work just fine.
Now stack five of these systems together. The resulting system is a HPF with -100 dB attenuation at 1 rad and no attenuation at 10 rads (disregarding the curving effect). It's a high-pass filter.
Regarding the energy inquiry, I do not really know the answer to that. Perhaps your teacher meant that to get high gains, one would need a physical system capable of producing high voltages/currents?
connect a resistor and capacitor in parallel
Place them as Zfeedback around an inverting op-amp
Connect another resistor and capacitor in parallel
place them as Zinput into same inverting opamp
and you have built a lead-lag element.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
