Moment of Inertia and Frequency of Oscillation
To calculate the moment of inertia from the frequency of oscillation, additional information such as the restoring force is necessary. The discussion describes a scenario where a body is pivoted and displaced, leading to simple harmonic motion under the influence of gravity. The relationship between torque and moment of inertia is established through the equation τ = I d²θ/dt². By applying the small angle approximation, the angular frequency ω can be derived, which relates to frequency f as ω = 2πf. This method effectively connects the moment of inertia with oscillation frequency.
UKDv12
How do you calculate the moment of inertia given frequency of oscillation?
You are going to need more than just the frequency. You will need to know the restoring force.
I think the problem you are describing is a body hung on a pivot through a point on it and the body is displaced by a small angle θ with gravity acting on the centre of mass to restore equilibrium. In the limit of small θ the body executes simple harmonic motion.
For angular displacements the equivalent of F=ma is τ = I d2θ /dt2 where τ is the torque about the pivot of gravity (mg) acting at the centre of mass and I is the moment of inertia about the pivot.
Put this together and use the approximation sin θ ≈ θ for small θ and as you would for a simple pendulum solve to find ω (= dθ/dt)
since ω (= 2 \pi f) you have solved the problem
Hope this makes sense and helps
regards
Sam
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
