Calculating Projectile Trajectories with Gravitational and Electrostatic Forces
The discussion revolves around calculating the landing positions of two positively charged projectiles affected by gravitational and electrostatic forces. The projectiles, each with a mass of 1kg and a charge of +1mC, are fired at a 45-degree angle with an initial velocity of 40m/s and a 1m separation. The time of flight is determined to be 5.77 seconds, with calculated y-coordinates of impact at +/- 160.2m. The challenge lies in setting up the calculus to solve for the x-coordinate, as the electrostatic force is inversely proportional to the square of the separation, complicating the acceleration. The conversation suggests using energy equations and references standard free fall in gravitational fields to approach the problem.
BOYLANATOR
I am an undergraduate physics student and found myself thinking about a scenario where two positively charged projectiles are fired at an angle to the horizontal at a velocity with a certain separation. So they will be subject to a gravitational force and perpendicular to this, an electrostatic force.
The distance dependent acceleration is something I have not covered before and am unsure as to how to calculate where the projectiles will land.
Lets give the projectiles a mass of 1kg and a charge of +1mC. Say they are fired at 45degrees to the horizontal with a velocity of 40m/s. They are fired in the same direction at the same time but separated by 1m. If we say this happens on a co-ordinate system, we can say they are fired from +/- 0.5 x, and parallel to the y axis.
I have worked out that the time of flight is 5.77s and that the y co-ordinates of the impact points are +/- 160.2m.
How can I set up the calculus to solve for x?
The gravitational force is vertical. By symmetry, the electrostatic force is always horizontal, in the x direction. If you're ignoring air resistance, there's no interaction between these. So you can treat the particles as repelling, and moving, purely in the x direction for the known flight time.
Again by symmetry, the repulsion on each ~ 1/x^2:
x'' ~ x^-2
Can you solve that?
Yes but neither the acceleration or the separation are constant so I am a bit confused.
Quite so. The acceleration (x direction) is as I indicated, is inversely proportional to the square of the separation (x direction). Can you solve that differential equation?
Sorry, yes you did show that.
Ok so I solve and get x=-c.ln(x)+x0.
Again I am unsure how to solve this.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
